Results 1 to 4 of 4
Thread: 6.2L OL SD e38 idle hangs high
    Feb 2019
    Default 6.2L OL SD e38 idle hangs high
    Last Sat took the car to its first show to mostly shake it out. It was only a ten mile round trip.
    Car ran great to the show idle was fine, started fine, and ran good till I got to the shop. When I slowed down the idle hung at about 2K. What?
    I have no clue what happened. Please look at the tune I was running 0006 and the tune I'm working on with a couple of changes 0008. ooo7 tune was a disaster...stumbled, hard start really rich so I reverted to 0006. I really don't know what a "good VE table" should look like. I don't know why the idle hung.
    I have included an excel file I created that shows the changes made to different tunes with param and desc. Hope that helps.
    I am a newbie working thru this with his rear ragged Thanks
    LS3 Manual 6 spd E38 os:12633056
    Texas Speed 1 7/8" headers w/3" exhaust
    Texas Speed cam 229/236 .629/.615 112 LSA
    Hi-Ram intake stock injectors 90mmTB
    Feb 2019
    I looked at other tunes for other GENIV e38 engines and captured pics of the ve table in B8101.
    Can anyone tell me which would be used over the other...they are so different!
Name:	38 jeep corvettectz.jpg
ID:	23564Click image for larger version.
ID:	23565Click image for larger version.
ID:	23566Click image for larger version.
Name:	monte carlo ss 08 E38ctz.jpg
    What intake manifold do you have...?
    How close to stock is your E38...?
    Feb 2019
    What intake manifold do you have...?How close to stock is your E38...?
    My engine/harness/ecm/injectors are all stock from 2010 camaro ss 6.2L. My intake in a hi ram intake with stock TB. My avatar/signature has the engine info.
  1. E38 High Injector Duty Cycle and High Map
    By nchristian in forum E37, E38 & E67 PFI ECM's
    Last Post: May 24th, 2017, 05:09 AM
  2. High Idle
    By DarkDiesel in forum Cummins 5.9L
    Last Post: December 28th, 2015, 11:56 AM
  3. Need help with high idle. (e38 conversion)
    By vortecyota in forum E37, E38 & E67 PFI ECM's
    Last Post: June 6th, 2014, 03:36 AM
  4. Sometimes communication hangs
    By Ira in forum FlashScan V2 BB Logging
    Last Post: January 2nd, 2008, 09:29 AM
  5. Idle hangs for a few seconds when coming to a stop
    By DaddySS in forum Gen III V8 Specific
    Last Post: September 4th, 2007, 07:52 PM
