Results 1 to 3 of 3
Thread: Some PIDS Unavailable Based On User?
    Jan 2009
    Default Some PIDS Unavailable Based On User?
    So I have a strange issue. Recently had to install EFILive on a new system, and in V7.5, one user account shows Engine RPM, Intake Manifold Pressure and Intake Air Temperature as invalid/unsupported PIDS. If I launch the application with a different user account, they all show as supported. There must be an easy fix for this. This is just bizarre to me. Can anyone help, please? It's driving me crazy. Thank you.
    Brad
    Hi Brad,
    From V7.5 scantool go Info->Validate Pids.
    The validated PIDs are stored in files per user - so different users may see different validated PIDs.
    The validated PIDs are stored in \Documents\EFILive\V7.5\PIDs\*.vpl
    (vpl=validated PID list)
    You could copy those *.vpl files form one user's account to the other.
    They are just text files, you can view their contents using Notepad.
  1. P12 crank sensor relearn unavailable?
    By kajon25 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: June 9th, 2016, 10:18 AM
  2. V8 User Calculated PIDs
    By Ninety8C5 in forum Tips and tricks
    Last Post: November 17th, 2013, 08:21 AM
  3. 0202005 is based on what OS?
    By Highlander in forum Custom Operating Systems
    Last Post: August 22nd, 2009, 09:37 AM
  4. Coolant based fueling
    By Highlander in forum Gen III V8 Specific
    Last Post: July 20th, 2009, 07:16 AM
  5. KR log PID's unavailable
    By pullincrazy88 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2008, 06:20 AM
