Results 1 to 1 of 1
Thread: October 2020, Release Candidate 5
    Default October 2020, Release Candidate 5
    ATTENTION - Release Candidate Software
    This software contains a new CSP switchable tune operating system for CMF controllers. It is an "early access" feature that is not intended for production use just yet. EFILive is looking for feedback on the performance of the CMF CSP OS. Please do not install the CMF CSP OS on remote vehicles. Only install it on vehicles in your workshop that you can recover easily if the CSP5 OS causes problems.
    For users dealing with the V3 AutoCal products you must use this release and ensure that all devices have the firmware updated to the version in this release prior to being used on vehicles.
    The current public release is available here.
    Full Release Notes:
    Version Numbers:
    After installing this beta release you should have the following software and firmware versions installed:
    • EFILive V7 software: V7.5.31 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.3.1 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • FlashScan/AutoCal V3 Firmware: V3.00.056 (Oct 22 2020). Boot block will be updated to V3.00.005. (no change since RC4)
    • FlashScan/AutoCal V2 Firmware: V2.07.167 (Oct 22, 2020). (no change since RC4)
    Download here:
    Known Issues for RC5:
    Issue #1:
    Can't compare VE tables between two tune files if VE units have been changed from g*K/kPa to % or g/cyl or g/sec.
    Workaround:
    Set the VE units to display as g*K/kPa - will be fixed in RC6.
    Feedback:
    To ask about features, request improvements or to simply provide feedback (positive or negative) on the new V8 editor, please use this thread: https://forum.efilive.com/forumdispl...V8-Tune-Editor
    Regards,
    The EFILive Team
    Last edited by cindy@efilive; November 3rd, 2020 at 02:33 PM. Reason: Removed links - new release avaiable
  1. October 2020, Release Candidate 4
    Last Post: October 27th, 2020, 11:03 AM
  2. October 2020, Release Candidate 3
    Last Post: October 16th, 2020, 06:14 PM
  3. October 2020, Release Candidate 2
    Last Post: October 6th, 2020, 11:07 PM
  4. September 2020, Release Candidate 1
    Last Post: October 5th, 2020, 01:46 AM
