Thread: V8 Scan Tool - Display Calc PID's on Charts
    Junior Member PHLTHS's Avatar
    Dec 2014
    Default V8 Scan Tool - Display Calc PID's on Charts
    Hi All,
    Does anyone know if it’s possible to display a newly created calc pid on the charts within the V8 Scan Tool Software?
    I have created a new calc pid using the editor and I also tested it using the Fx checker, however it doesn't appear in the list of PID's available when trying to select it for the charting.
    Thank you.
    HSV W427 / HSV SportsCat SV
    Yes... under Scan, look on the right "Available Pids", look under "Custom Pids".
    Post your UserCalculatedPids.ini file here (you have to append .txt to the filename).
    You could also just export a specific group of calc PIDs rather than the entire file.
    Importing/Exporting is also a convenient way to share calc PIDs between users.
    Dec 2014
    Hey Paul,
    Anyway to import all calc pids from V7.5 into V8?
    Dec 2014
    Thanks Joecar, with your help I ended up figuring it out.
    Cheers sir.
    Quote Originally Posted by PHLTHS View Post
    Hey Paul,
    No sorry, they are much too different to automate the conversion process reliably.
  1. Replies: 3
    Last Post: October 20th, 2019, 01:59 PM
  2. V7.5 Scan Tool cannot load valid PID's
    By mschmitz1867 in forum General
    Last Post: March 11th, 2018, 06:11 AM
  3. Calc pid to display previous frame value (delay data)
    Last Post: February 13th, 2017, 02:25 AM
  4. Logged E40.SCALEDCORVE_DMA won't display in V7.5 Scan Tool
    By ACCLR8N in forum Black Box Logging
    Last Post: August 22nd, 2013, 03:46 AM
  5. Can't select RAFIG PID's in either BBL or Scan tool!
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 22nd, 2009, 01:53 PM
