Results 1 to 10 of 18
Thread: e92 Cam position tables
    Jun 2019
    Default e92 Cam position tables
    Doing a tune on a 2017 l83 and looking at the cam position tables (b7934, b7935, b7936) and the x axis does not look anything that I am use to... Not sure if I am missing something.
    If it is correct, how do you log vvt with the scan tool? I am logging e92.apcyl_dma, rpm and gm.incamab1 and nothing aligns in the table from the scan. Thank you for any help.
    Aug 2016
    Have you tried logging GM.INPHAB1 to see if Actual angle appears? I'm not sure about the PID you posted.
    What ECM OS is that in?
    Jun 2019
    Quote Originally Posted by RC1 View Post
    The one that I am logging is Intake Cam Actual Phase angle.
    The OS is 12677878
    Jun 2019
    Not sure if it is related, I tried to log GM.INPHAB1 but as soon as I tried to record OR monitor, no data would update. It looked like all the data was static and like i was not monitoring/recording at all. Once I removed that pid, everything went back to normal.
    GMPX - were you able to find anything?
    Also try GM.EXHCAM1DC.
    Jun 2019
    What is the benefit of this pid? If I understand correctly, this is the duty cycle for the exhaust cam. In a crude way, will this not just tell me how much oil is being diverted to the phaser?
    I guess in another way, can anyone share what pid's they are logging when they tune vvt on an e92 ecm? Also, has only else seen what I shared in the screenshot?
    Jun 2019
    Ttt
    Aug 2016
    It looks as if the first 5 Column labels are completely wrong.
    Jun 2019
    TTT.
    Is there anything that I can do to correct the lables or is it in the calibration file?
  1. Cam Phaser idle position
    By pir4te in forum General (Petrol, Gas, Ethanol)
    Last Post: January 13th, 2018, 06:31 AM
  2. Pedal Position Tables
    By Import_Dude in forum Duramax 2011+ LML / LGH
    Last Post: April 17th, 2017, 09:08 AM
  3. E80 - Cam Position PID Missing
    By Giambals in forum Petrol / Gas
    Last Post: December 12th, 2016, 04:12 PM
  4. B7968 Cam Position Full Throttle
    By efilivesteven in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 1st, 2016, 01:39 PM
  5. Cam position retard procedure. getting error p1345
    By bubba68ss in forum Vortec V6/V8 Specific
    Last Post: September 29th, 2012, 04:19 AM
