Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Gmpp lt4
    Lifetime Member Road's Avatar
    Feb 2015
    Default Gmpp lt4
    ISO a GMPP LT4 Cal OS12677012. Anyone happen to have one?
    Dec 2016
    Quote Originally Posted by Road View Post
    Here ya go
    -Carl
    Dec 2016
    No problem, glad to help.
    I generally try to read everything I run across for my personal archives. In the past I would at least get the file in .bin format even if I wasn't going to tune. It appears efilive won't open .bin files anymore so I'll have to change my strategy, or maybe that is only on some of the newer ECM's. Now, I must admit I am still using an older version of 7.5 and 8 due to having an XP machine. Did the .bin feature change in the newer updates?
    Quote Originally Posted by In-Tech View Post
    Yes it does, every controller EFILive supports can load in as a .bin file as long as the size and structure is what the software expects.
    Dec 2016
    Hi Ross, Here is the .bin file compressed with winrar. I am currently using v8.2.24, boot 2.07.008, firm 2.07.140 and v7.5.28. Neither will open this file. Maybe the GMPP format isn't recognized? Did I read it correctly that I will have to use a Win7 or newer laptop for future upgrades?
    Last edited by In-Tech; November 4th, 2020 at 03:42 PM. Reason: Removed invalid file
    Well whatever read that ECM to create the .bin file didn't actually read the whole thing. The section EFILive uses to determine the ECM type when a bin file is being loaded is missing.
    Dec 2016
    Thanks Ross,
    I just recently started messing with the E92. I'm going to mill one open in the next couple weeks and figure out what I'm missing. I'm glad I read it out with your great software, it helped one guy
    I'm confused Carl, the file you posted 'LT376_535hp_E92_Stock.ctz' was certainly read with EFILive but the .bin was not.
    Did you need help with the bin still ?
    Dec 2016
    Hi Ross,
    I think what I did read of the bin file is correct but am missing where the vin and serial is stored so I have to research that a bit. No need to clutter this thread. I love your software and have no problem buying a license when I need to work on something. I've been fooling with this stuff since the early 90's and pretty sure Paul was around back then when the Ohio state majordomo was around(you might have been there too). I recommend your product whenever a customer wants more control
  1. Lt1, lt4, l83, or l86 e92 gmpp connect and cruise tunefile wanted
    By 04colyZQ8 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: May 15th, 2018, 12:46 PM
  2. GMPP LS3 with GMPP Controller Tacho control
    By TurboCamaro in forum Conversions / Aftermarket Parts
    Last Post: December 4th, 2010, 01:37 AM
  3. 58x for SBC, BBC, and LT1/LT4
    Last Post: January 14th, 2010, 05:34 PM
  4. lt4 tuning help
    By darren250r in forum Vortec V6/V8 Specific
    Last Post: May 16th, 2009, 11:53 AM
  5. LT4?
    By ToplessTexan in forum General
    Last Post: December 23rd, 2005, 02:42 PM
