Results 1 to 6 of 6
Thread: Can I trick the pcm into giving a actual 14.2 AFR in closed loop??
    Jun 2005
    Default Can I trick the pcm into giving a actual 14.2 AFR in closed loop??
    I want to have idle remain closed loop, but I need a little richer AFR at idle. Can I somehow adjust a multiplier table to remove a little fuel or something in the idle area. I have to look arund and see if there is something I can manipulate.
    When the computer is commanding a 14.7:1 AFR for idle, i want my wideband (actual AFR) to be a little richer. Just at idle.
    I want to do this to give the idle more consistancy in closed loop vs. open in my SD tune. Being that it would be so close to Stoich, it should be very accurate.
    Any thoughts?? Do people do this already? I need to scroll around my laptop and look how I can do this tonight!
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
    Oct 2004
    You could try setting B3601 to that value. If you don't have that table in your OS then it is hardcoaded to 14.63:1 in which case I don't thing so in Closed Loop.
    Andrew
    EFILive Crew
    foff667
    Guest
    I've never gotten into messing with the stoich a/f ratio...I will say if you do try that it will throw your other tables off since thats a reference table so just keep that in mind.
    Jun 2005
    Hmmmm..... A challange!
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Oct 2004
    Quote Originally Posted by foff667
    Good point.. Anything that uses EQ Ratio will but offset as a result of this change.
    Andrew
    EFILive Crew
    Aug 2005
    You could change the O2 switch point {B4105}. Problem would be knowing what exactly 14.2:1 would be on a narrowband...
  1. How to REALLY shut of closed loop/ force open loop
    By Tomato in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 03:37 AM
  2. Not going into closed loop
    By tblu92 in forum Gen III V8 Specific
    Last Post: February 12th, 2008, 10:22 AM
  3. closed loop and open loop switching
    Last Post: July 10th, 2006, 08:56 PM
  4. Closed Loop......Why?
    By GMPX in forum General (Petrol, Gas, Ethanol)
    Last Post: February 16th, 2006, 03:58 PM
  5. Open Loop SD VS Closed Loop SD Advantages???
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2005, 12:25 PM
