Results 1 to 10 of 12
Thread: Current Public Release November 2020
    Nov 2005
    Default Current Public Release November 2020
    IMPORTANT
    For users dealing with the V3 AutoCal products you must use this release and ensure that all devices have the firmware updated to the version in this release prior to being used on vehicles.
    Full Release Notes:
    Version Numbers:
    • EFILive V7 software: V7.5.31 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.3.1 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • FlashScan/AutoCal V3 Firmware: V3.00.056 (Oct 22 2020). Boot block will be updated to V3.00.005.
    • FlashScan/AutoCal V2 Firmware: V2.07.167 (Oct 22, 2020).
    Download here:
    Known Issues:
    Feedback:
    To ask about features, request improvements or to simply provide feedback (positive or negative) on the new V8 editor, please use this thread: https://forum.efilive.com/forumdispl...V8-Tune-Editor
    Regards,
    The EFILive Team
    Lifetime Member Road's Avatar
    Feb 2015
    Appears to be a issue with the download links. People report links don't work and not downloading for me either.
    I had to right ckick and open in a new tab to get them, same things happened on most of the previous ones for a while for me.
    04 LB7
    2010 LMM
    2015 LML
    Jun 2011
    I had to right click as well and open in a new window for download.
    Sent from my SM-G960U using Tapatalk
    Quote Originally Posted by Road View Post
    Seems to be an issue for Chrome browsers only (from what we've heard), maybe they have introduced some sort of link blocking?
    Feb 2015
    Right clicking works. Thanks for the help!
    Dec 2012
    Is it possible to have the Try Key Range for unlocking LLY and LB7 controllers accept a hex value? It seems to only take decimal. But if you enter a Hex value, you get no error, and it just resorts to running the "Try Stock Key" Option.
    Josh
    '04 GMC LLY
    I think if you prefix the hex value with $ it will accept it. Like $0000 and $FFFF.
    Note: that should be true of most integer fields in the software. The String to Integer conversion in Delphi recognizes the $ as a hex prefix (i.e. not 0x like "C" uses).
    Dec 2012
    Giving this a try.
    I did get it going, but after about 2225 keys it said "Locked with custom Key" So i checked the "Restart" box and now its just running like if you have "Try Stock Key" checked... its not restarting. It just does this....
    Josh
    '04 GMC LLY
    Giving this a try.
    When it says "Locked with custom Key", that means it has tried all the keys in the range specified. There is no "restarting" in that case - since it has tried all the keys in that range.
    Restarting is only useful if you stop it (or it crashes - i.e. battery failure etc) before the complete/requested range has been tried. The reason a restart option exists is because the keys are not tried in numerical order. They are tried in a random order but in such a way that all keys in the range are tried only once.
    So let's say you were trying keys in the trivial range 1..10. It might try the keys in this random order: 4, 2, 7, 5, 1, 10, 9, 6, 8, 3. Then assume you aborted it after it had tried only these 4 keys: 4, 2, 7, 5. As the user, you don't know which keys have or have not been tried, you only know that 4 keys have been tried. You might assume that keys 1, 2 ,3, 4 had been tried, so to continue you might incorrectly set the range to 5..10 to try the last 6 keys. However, because the keys are tried in a random order, keys 1 and 3 would not ever get tried - since it tried 4, 2, 7 and 5 in the first try and then 5 thru 10 in the second try (missing keys 1 and 3).
    If you had a range of 1..1000, then it would try all 1000 keys in random order. If it completed all 1000 keys and did not unlock the ECM then it would show "Locked with custom Key". If it was stopped by the user or aborted in some way before trying all 1000 keys then using the restart option would restart at the most recently tried key in the range 1..1000 (you can't change the range when using restart).
    If it had finished the 1..1000 and you wanted it to try 1001..2000, then you would enter the new range 1001..2000 and just click [Cal Flash] to start that new range.
  1. November 2020, Release Candidate 6
    Last Post: November 11th, 2020, 02:41 PM
  2. Current Public Release (May 2018)
    Last Post: July 5th, 2018, 11:36 AM
  3. Known Issues With Current Public Release
    Last Post: March 22nd, 2017, 11:42 AM
  4. Known Issues With Current Public Release
    Last Post: February 17th, 2017, 07:06 AM
  5. Known Issues With Current Public Release
    Last Post: January 31st, 2017, 12:02 PM
