Results 1 to 6 of 6
Thread: I Move My Documents and Pissed Off EFILive
    Mar 2009
    Default I Move My Documents and Pissed Off EFILive
    I've been away from this software since July and all of a sudden it acts like a bunch of stuff got uninstalled. I'm pretty sure what really happened is I relocated the My Documents folder to my E partition since then and messed everything up. Am I able to tell an installed version of EFILive to look in the E drive now for everything that goes in the C drive My Documents folder without a reinstall? I copy/pasted over all the User Configuration stuff into the C drive as there was leftover old V7.5 stuff in there already. It would also be nice if I could give EFILive a new default location for things like maps, pid lists, tunes, logs, etc as I like to keep that stuff outside the default location for instances such as these where I'm likely facing a reinstall of the software.
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Why not point you 'My Documents' folder to your new location? I Believe thatvwoukd make efilive look there.
    Sent from my HTC U11 using Tapatalk
    Mar 2009
    I did that and that only fixes the Windows shortcuts. I don't know how to tell EFLive to look in the E drive vs the C drive, I may just copy/paste everything back to the C drive to fix that.
    Jan 2006
    That's odd... My 'My Documents' is redirected to a network location and efilive is fine with it.
    Mar 2009
    Was your folder relocated prior to installing EFILive?
    Mar 2009
    Yes it did. Sorry, forgot to check back.
  1. EFI live tune will not open documents
    By jrad12381 in forum FlashScan V2
    Last Post: June 23rd, 2012, 10:42 AM
  2. Bootload Error I'm pissed!!!!!!
    By Hawks Fan in forum Duramax LLY
    Last Post: February 2nd, 2011, 06:12 AM
  3. Move V2 License Back to V1?
    By duramax2500hd in forum FlashScan V2
    Last Post: September 20th, 2009, 08:57 PM
  4. Move Dashboard from V6?
    By Ed Blown Vert in forum General
    Last Post: April 28th, 2005, 04:15 PM
