Results 1 to 6 of 6
Thread: V2 died?
    Mar 2009
    Default V2 died?
    Out of nowhere I went to use my V2 to pull some codes out of my truck and all I got was this. Tried a different vehicle as a test and same thing. Three LEDs lit continuously and screen is blank. Doesn't matter if I power up via laptop or by an OBDII port I see the same result. Removed/reinstalled SD card several times with no change. Is it dead? Not sure what to do.
    Nov 2005
    If you have checked OBD power (without USB connected) and you get the same result you could try booting FlashScan in one of the special power up modes listed here https://service.efilive.com/kb/artic...power-up-modes
    Cheers
    Cindy
    Mar 2009
    Thanks Cindy.
    I just tried all three boot up methods, powering up via USB then OBD individually and only see the same results as before. Nothing but the three leds.
    Jan 2011
    I am having the same issues, It happened after I used a bench harness to flash an E38, it is a harness I have used dozens of times before.
    I tried the boot methods mentioned above and no go, the computer does see the V2 but it doesn't respond. Codes are as per blinking lights: $0081 and $0082.
    Is this repairable?
    Mar 2009
    I don't even get any blinking lights, they're all just illuminated steady as seen in the pic. When connected via USB all I get is a "device not recognized" notification. No screen or anything on the V2.
    Nov 2005
    Can you please create a ticket on our help desk for support to look at your issue? https://service.efilive.com/new-ticket
    Cindy
  1. LM1 died
    By minytrker in forum Lounge
    Last Post: February 6th, 2011, 01:36 AM
  2. RR Died today
    By Highlander in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 19th, 2009, 06:40 PM
  3. Laptop Died
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2007, 10:12 AM
  4. RR died
    By minytrker in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 7th, 2007, 02:16 AM
  5. Died around 4200rpm
    Last Post: April 19th, 2007, 11:54 AM
