Results 1 to 8 of 8
Thread: Segment Swap in V8 Editor
    Lifetime Member blindawg's Avatar
    Sep 2010
    Default Segment Swap in V8 Editor
    Am I missing this in the tutorial? I'm enjoying the rest so far! Everything is much less "Clunky" when opening new files.
    Quote Originally Posted by blindawg View Post
    May 2010
    What Disable checksum used for ?
    EFILive Tuner
    Disabling the checksum is not recommended. That will cause the controller to not validate the data in the ECM. If any data gets corrupted, the ECM will continue to operate without knowing/detecting that the data is faulty. That can cause serious problems.
    That option was added to the software to support real-time tuning - which is where a specially constructed ECM (like the LS1 RoadRunner) allows the calibration data to be modified on-the-fly while the ECM is running the vehicle's engine. By disabling the checksum the calibration data is changed in the ECM can be changed without triggering the ECM's data corruption detection and going into limp mode.
    Disabling the checksum is not a useful or prudent thing to do in any other scenario. The fact that we don't support the RoadRunner ECM in the V8 software means that disable checksum should not really be active in the V8 software.
    There are some updates to the segment import/export.
    Currently in V8.3.1 you can only import an identical segment part numbers. It has been updated in V8.3.2 to:
    • Allow importing of different segment part numbers - so long as the OS number matches.
    • Export multiple segments simultaneously.
    • Use a more logical directory hierarchy.
    May 2010
    Thanks Paul
    What about make all checksum zero
    Does it mean to copy all segments ?
    EFILive Tuner
    Thanks Paul
    No, that just sets the checksums for each segment to zero. Again that is not a useful thing to do - some tuners have requested that feature for their own purposes. I think it has to do with third party hand-held tuners and the way some of them modify the ECM to deal with checksums.
    With the next update V8.3.2 you can select all segments (except the boot block /OS segments) and export them all in one go.
    Then you can import all or just selected segments into a different tune file (with the same OS number).
    That update should be available in the next day or two.
    Jan 2009
    As someone who is late to the V8 editor party but is finally coming over to embrace the new stuff this works awesome! Good job. I like how you can make a library of exported segments and just easily pull in what you need.
  1. Help with segment swap
    By 12sec.5.3 in forum Gen III V8 Specific
    Last Post: March 17th, 2018, 08:39 AM
  2. 4l80 swap with frost harness without segment swap
    By james workman in forum Conversions / Aftermarket Parts
    Last Post: March 10th, 2017, 04:12 PM
  3. What does a segment swap do?
    By Mean Green Z28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 6th, 2016, 07:52 AM
  4. How do you do a segment swap?
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 8th, 2012, 08:18 AM
  5. Segment swap...Q's???
    Last Post: November 6th, 2007, 07:14 PM
