Does anyone know how to import a calterm bin file in to efi live, it is saying file block size does not match controller block size...
You have to use the XCal import tool (included with EFILive) to first convert the .xcal from that format to a .bin file that is set out exactly how EFILive wants it.
Then you should be able to load the .bin file directly into V8.
If a binary file is exported from CalTerm and then imported into EFILive via this XCAL, how is the transmission section handled? I thought the trans was calibrated by FCA, wouldn't think it would be in CalTerm.
The 68RFE cals are within the same flash area as the engine cals, I have no clue on what is or is not in CalTerm so I don't know.
Found the import tool, worked beautifully
There are sections in the definitions that do define trans parameters and inputs so I assume it is in there, my truck is an asin so I can't tell you with 100% certainty
CM2350B could potentially refer to a product model, part number, or a specific topic. If you could provide more context or details about what you need assistance with, I'd be happy to help you further.
Uno Online
