Results 1 to 9 of 9
Thread: E38 Gen4 Big cam running 12 afr at idle and won`t change
    Feb 2020
    Default E38 Gen4 Big cam running 12 afr at idle and won`t change
    Good Morning Gents/ladies I have put a big cam in my gen4 and I can`t get the idle to be leaner then 12 afr. I have tried allot of different things to no resolve. The log says the afr is commanded at 14. something but the wide band is saying 12 afr. I have dialed the vve in also. Could someone point me in the right direction please? Cheers
    Log_0003.efiE38 fd man ._0156.ctzClick image for larger version.
Name:	cam specs.jpg
    Dec 2016
    Hiya,
    I'll look at your file later tonight and see if anything jumps out. What injectors do you have?
    Off topic but curious, does that cam make a lot of valvetrain noise?
    Feb 2020
    Quote Originally Posted by In-Tech View Post
    Hiya,
    Hi thanks for the reply , The valve train doesn`t make much noise , but I haven`t heard a stock engine for a while. I`m making a bit of head way . On p0101-3 i set to 1 trip and no mil , and now when I start the engine the afr goes from 14.6 afr and slowly richens up to 12 afr over about 5 seconds. Thanks for having a look.
    E38 fd man ._0159.ctz
    Dec 2016
    I haven't updated to the latest efilive software and can't look at your file. Just off the top of my head I would have a look at your min inj pw. If it is an aftermarket wiring harness, the injector offsets will have to be changed and a lot more if the injectors are not stock.
    Aug 2013
    In-tech.... it's a locked auto-cal file.
    I guess his tuner is going to have to sort this mess out by himself.
    Dec 2016
    Thanks statesman. I don't usually spend much time looking at others' tunes, so Lucy says thanks for 'splaining. Most times if altered I just start over with a stock file and go from there
    -Carl
    Feb 2020
    Update all fixed.
    What fixed it?
    Feb 2020
    What fixed it?
    Pulled about 45% out of the ve table also changed b0146. Still working on cold start atm runs like a hairy Bill Goat when you start it for 20 seconds or so.
  1. Big cam LS7 idle issues, looking for a bit of assistance.
    By SilverbulletC6Z in forum Gen IV V8 Specific
    Last Post: June 26th, 2019, 03:14 PM
  2. Cannot change idle speed on E38 PCM
    By njedwardz in forum E37, E38 & E67 PFI ECM's
    Last Post: April 27th, 2016, 06:19 AM
  3. Replies: 28
    Last Post: November 23rd, 2015, 05:30 PM
  4. E38 08 LS7 cam/milled heads won't run in SD mode
    By Age08 in forum E37, E38 & E67 PFI ECM's
    Last Post: May 28th, 2015, 02:06 PM
  5. 97 Vette big cam idle surge (first post to forum too )
    By oldvette in forum Gen III V8 Specific
    Last Post: September 5th, 2009, 07:04 AM
