Trying to get calc_pids.txt set up before I go outside and freeze to death and hook up the wires to the flash scan v2. I'm trying to follow the AutoVE tutorial and this is my first time attempting this so bare with me.
Using an AEM 30-0300. Connecting to the flash scan via analog connection. I want to log lambda values and set up the BEN to use lambda, also. From what I have read this will make things easier? Attached my current file. Hopefully somebody can tell me if I have done this correctly.
https://www.aemelectronics.com/files...ns/30-0300.pdf
