Results 1 to 3 of 3
Thread: reductant tank empty message wont clear
    Jan 2007
    Default reductant tank empty message wont clear
    hi all, i know there is no support for emmisions modified units but i will ask anyway
    have a 2015 lml, had it deleted and now reductant tank empty message is on
    have efiive and not in usa.
    can someone tell me which setting i missed.
    operating system is 12660477
    Jan 2020
    You probably missed a CAN transmit or receive disable. That's where I would start. Also, look at all calibrations with DEF in the name and make sure they are set correctly for your application.
    Jan 2007
    Quote Originally Posted by whistler View Post
    yep, missed the settings in the speedo segment
  1. Replies: 1
    Last Post: May 20th, 2018, 02:01 PM
  2. Stock Base File Causing DEF Tank Empty Message
    By powerturn in forum Duramax 2011+ LML / LGH
    Last Post: July 5th, 2017, 12:53 AM
  3. 2015 lml reset reductant quality poor message,
    By mrrattle in forum Duramax 2011+ LML / LGH
    Last Post: May 25th, 2017, 12:22 AM
  4. PCM Pin Outs, Can These Be Reprogrammed (Empty Pins)?
    By Level2 in forum Gen III V8 Specific
    Last Post: August 9th, 2015, 03:21 PM
  5. Empty Box
    By curtbriggs in forum General
    Last Post: March 6th, 2005, 12:54 PM
