Results 1 to 10 of 14
Thread: New to tuning.
    Dec 2020
    Default New to tuning.
    I’m new to tuning and looking for some direction. I have a 98 Z28, with an LS6 intake, long tube headers, off-road y-pipe, B&B cat back, and SLP cold air intake. I know that I am running rich due to the soot on the exhaust tips and the smell of the exhaust. Any advice on where to start with my tuning?
    Last edited by Steven LS1 Z28; December 29th, 2020 at 06:52 AM. Reason: Incomplete posting.
    Mar 2009
    I seem to recall the F bodies commanding more WOT fueling than the Corvettes and also having less ignition advance. At least on the stock tunes I'd looked at years ago. Do you have a wideband? Your best bet would be to tune the VE/MAF then command a WOT AFR of something more akin to 12.7-13:1 vs the factory pig rich settings.
    Aug 2013
    Quote Originally Posted by Supercharged111 View Post
    I don't normally challenge the advice you give, but this time I have to. Seriously, 13.1 AFR at WOT? In my opinion that's too lean... and considering you don't even know what fuel he's running, it could end up putting him in a situation where he gets very little enrichment at all.
    Dec 2020
    I do not have a wide. I use only 92 or 93 octane unleaded.
    Mar 2009
    Quote Originally Posted by statesman View Post
    Sorry, I was assuming premium fuel here as that's what the car calls for. 13:1 is the number I have seen slung around for the LS1 by folks with dynos. If you've observed otherwise I'm open to more input. In the absence of a wideband dude is dead in the water. I think we can all agree that 12.5:1 is a universally safe AFR for an NA engine though.
    First step is to buy a wideband, without one, you're shooting in the dark as far as what your actual fueling is.
    The 97-98 PCMs are super limited and you have to deal with a Secondary VE table plus there are limitations around running SD as well. The later 99-02 512kb PCMs don't have this limitation and it's a pretty quick swap if you need more tuning support and functionality.
    Aug 2013
    Yeah, I guessed that was your logic... but people will use shit fuel if that's the only fuel available in their area. I never assume what fuel is being used, I always ask.
    I'm observing a newbie who doesn't even have a wideband yet, let alone a dyno. I would suggest a newbie (with a wideband) shoot for 12.2 or 12.3, and a more experienced home tuner should shoot for 12.5 or 12.6. Personally, I think 13.1 is too lean even for an expert dyno tuner... but that's just my opinion.
    Dec 2016
    Good call statesman,
    The overlap cycle has a lot to do with what the wideband sees. There is no magic AFR/Lambda number
    Dec 2020
    Ok next question. Any recommendations on a good affordable wideband and where to install it? I have read on other forums driver side or passenger side, with no real consensus on where.
    Mar 2009
    You bring up good points, in addition he'd be smart to leave some wiggle room in there in case he misses something when he does get it tuned with a wideband. If memory serves correct, the stock PE AFRs commanded were well into the 11s.
    Steven I have an AEM gauge in my 1500, I want to say I only paid around $125 for it back in 2009. It has a couple wires that allow you to make a serial cable for it to get it talking to the Flashscan.
  1. Tuning question Road tuning
    By ToonerSQUAD89 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 30th, 2020, 02:19 PM
  2. GM495HP Crate Engine Idle Tuning and T42 4L70E Trans tuning
    By Schwanke Engines in forum E37, E38 & E67 PFI ECM's
    Last Post: August 24th, 2018, 04:39 AM
  3. Replies: 7
    Last Post: June 1st, 2012, 04:26 PM
  4. 08 Silverado 5.3 Tuning, tuning-spark/pe mode/
    By hulm333 in forum Gen IV V8 Specific
    Last Post: November 16th, 2009, 04:44 PM
