Results 1 to 5 of 5
Thread: Active Fuel Management
    Junior Member Strong05's Avatar
    Sep 2010
    Default Active Fuel Management
    Wasn't clear in the EFI website if active fuel management could be disabled for the E82 ECU, or any other ECU for that matter. Can anyone let me know if you can turn this off in the tune? To EFI Live: A more comprehensive list of features for each ECU would also be greatly appreciated. Thank you in advance for any help!
    2000 WS6 T/A White M6, Mods: SLP Lid, Pro 5.0, LS7 clutch, QTP headers, LS6 intake, UMI: adj TA, BMR: LCA, STB, SFC, and adj PB. Best ET of 13.7 @ 107mph.
    I'm not that familiar with the E82, so there may be other scenarios I'm not aware of. The only vehicles I see using this ECM are 3.6L V6s in a few platforms, none of the V6s appear to have AFM. There may be the switch in the ECM code, but if the engine doesn't have the physical hardware to support it, it won't be usable. EFILive supports 2016-2018 E82 only.
    For E38, E67, E40, E92, yes you can disable AFM in the tune.
    Mar 2020
    Am I able to delete the AFM on a 2017 Chevrolet 6.2 I'm new to EFI and was reading something about the 17's being harder due to added security.
    I don't believe the added security changes this, it's still an E92 so this should be possible.
    Do you have EFILive? If so, read the tune out (you'll need a Controller Authorization code to do so), then you can confirm the parameter is available (or post the file here).
    Sep 2010
    Thank you both for the feedback! Yes I have a V2, but I don't own the ECU in question. I am in the market and wanted to see if EFI supported turning this off for the vehicle I was looking at.
    Thank you again for your input!
  1. Afm ( active fuel management ) aka d.o.d.
    By djv86 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 15th, 2014, 05:48 PM
  2. Active Fuel Management controls?
    By XLR8NSS in forum General (Petrol, Gas, Ethanol)
    Last Post: January 20th, 2011, 10:39 AM
  3. Question about AFM (Active Fuel Management)
    By Hollis1 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2008, 03:30 PM
  4. Wiring for Active Fuel Management
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: May 5th, 2008, 10:28 PM
  5. Disabling Active fuel Management
    By taz06 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 30th, 2006, 11:25 AM
