Results 1 to 3 of 3
Thread: Can't past labels
    Oct 2010
    Default Can't past labels
    I am using my V8 to setup some maps. The one i am working on is the MAF table using Hz and the data is EQ error percentage. When I go to the tune and copy with labels then try to past it into the map setup it doesn't past any of the column Axis in. I even tried to do it all manually but it came out all funky, any ideas?
    The "column axis" runs across the top and should only contain a single value
    The "row axis" runs vertically down the left and should contain all the frequency values.
    So select the [Row] tab page and click on the [Paste] button to paste the frequency labels.
    Manually configure the column label like this:
    Thanks.
  1. B6612 Labels verification
    By wesam in forum Gen III V8 Specific
    Last Post: April 13th, 2018, 03:57 AM
  2. Replies: 3
    Last Post: September 10th, 2012, 03:03 AM
  3. Mislabeling: IFR & IPVA Row Labels
    By RWTD in forum Gen IV V8 Specific
    Last Post: April 18th, 2011, 09:55 AM
  4. Map Kpa Labels For 2bar
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2005, 04:18 PM
