Results 11 to 20 of 22
Thread: 2020 Cummins stock files
    Jan 2021
    Quote Originally Posted by smokinpete379 View Post
    I have 32370731AH. I don't see AI but if I find it I'll throw it up
    Attachment 23637
    Thank you
    Aug 2010
    Anyone have S5361032SB for 2020 RAM ? Will pay for it
    Jan 2020
    That file is quite new as it's a service flash. You may be best off to go back to the predecessor file.
    Aug 2017
    Quote Originally Posted by horst View Post
    Having trouble finding that one. What is your engine serial ? I will download it for you.
    EFI Live HD Beta Tester
    Aug 2010
    Quote Originally Posted by whistler View Post
    Not possible to go to an older version. They changed the cam design for the fuel pump and exactly this flash is working only on this car.
    There are 2 flash numbers now depending on what fuel pump is installed.
    Jan 2021
    Attachment 23637
    I think I found AI and lets see if I can figure out attachments
    Senior Member Jim P's Avatar
    Nov 2019
    Anyone have the 52190700 68RFE and 52200300 68RFE files? Would prefer .bin but will take .ctz. Apparently my versions I have are too "new" for CSP.
    Jan 2020
    Quote Originally Posted by Jim P View Post
    2019 and 2020 service releases. I have both.
  9. #19
    Nov 2019
    They upgradable to CSP? If so, could I get the 2020 from you? I was able to get the 2019 through a fellow tuner but he didn't have the 2020 CSP upgradable one.
  10. #20
    Jan 2020
    52200300 is able to be converted to CSP5. Here you go.
    52.20.01.08 - IA80011.04 52370031AE 2020 DJ 2500 6.7L PCM 68RFE.ctz
  1. Full Set of Cummins & Partial Duramax Stock Files.
    By Move'n Up in forum General (Diesel)
    Last Post: October 22nd, 2019, 12:16 PM
  2. New to cummins - Where can I get stock cummins files?
    By GabrielMga in forum Cummins 6.7L
    Last Post: July 8th, 2016, 12:20 AM
  3. Replies: 8
    Last Post: April 20th, 2016, 11:24 PM
  4. Stock Files
    By BigCE in forum Duramax 2011+ LML / LGH
    Last Post: February 20th, 2015, 04:34 PM
  5. Cummins 5.9L Tune files
    By ScarabEpic22 in forum Cummins 5.9L
    Last Post: June 9th, 2011, 02:59 AM
