Results 1 to 4 of 4
Thread: Slight stumble warm start
    Jan 2015
    Default Slight stumble warm start
    Hello I have an LS1 B pcm on a 98 Chevy truck with the l31 engine. I've been adjusting warm start, 168F plus. The Truck always started well but I'm just looking for a louder/ more solid start. I've adjusted startup air which now makes the truck hiccup when starting. I've lowered initial fuel prime and cranking fuel which helped but still not quite there. Anything else worth looking into?
    Jan 2015
    So for example, when the truck starts now, it fires, small miss then runs, rpms go up (startup air) then they come back down. Trying to make it so it starts at the higher rpm then comes down and eliminate this small hiccup/miss.
    Mar 2009
    What was wrong with it before? Mine was always spot on until I did the marine intake and blower.
    Jan 2015
    Quote Originally Posted by Supercharged111 View Post
    There was nothing wrong with startup before I touched anything.. I may just return everything to the way it was but I wanted to experiment first. I really like the way the new dodges start, loud at first then quiet down right away. I was just trying to get my truck to do that if possible.
  1. Warm Start Problem
    By pormgb in forum General (Petrol, Gas, Ethanol)
    Last Post: June 26th, 2011, 02:30 PM
  2. Slight stumble at idle (intermittent)
    By frcfed347 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: May 25th, 2011, 11:17 AM
  3. Cold start perfect, Warm start flares high
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 09:36 PM
  4. Cold start great but warm start sucks."Idle
    Last Post: October 26th, 2008, 12:22 AM
  5. warm start issue
    By thomas walters in forum Gen IV V8 Specific
    Last Post: October 16th, 2007, 06:40 PM
