Results 1 to 3 of 3
Thread: misfire logging
    May 2019
    Default misfire logging
    Hello,
    I am chasing a cold start misfire on a 2008 GMC Yukon XL (6.2L). I am logging the typical parameters and the current misfire PIDs (MFCYL1C through MFCYL8C). I could be doing something wrong since the MFCYL*C PIDs are getting values of zero. I am using V8 software and a FlashScan V2. A couple of log files are attached. Thank you for any help.
    May 2019
    Good morning, folks. Still chasing this issue.
    I found the quote below on the Snap-on scanner forum, which may be relevant to why I'm not seeing non-zero values for MFCYL*C PIDs:
    "Look for the pid called "Cycles Of Misfire Data". It should be counting up from 0-99 and then start the cycle again. If the value doesn't increase, the PCM will not recognize misfires, even if it only runs on a single cylinder."
    Credit for the above is given to the user Orevin on the Snap-on forum.
    Entire thread is linked here:
    http://askatech.autorepairdata.com/f...ad.php?t=11072
    Still chasing...
    The PCM has conditions for looking at (and counting), and for ignoring misfires (and not counting)... seems like the is the latter situation.
    Thanks for posting (I'm learning all the time)
  1. Help with a Misfire Please
    By GhostC6 in forum Petrol / Gas
    Last Post: April 10th, 2020, 09:24 AM
  2. LS6 Misfire
    By pormgb in forum Gen III V8 Specific
    Last Post: November 30th, 2014, 09:38 PM
  3. Question About Logging Misfire Data
    By swingtan in forum General
    Last Post: June 9th, 2014, 01:38 AM
  4. misfire problems
    By Gregs in forum Petrol / Gas
    Last Post: June 25th, 2010, 12:45 AM
  5. misfire help
    By NviouSS in forum General
    Last Post: June 3rd, 2006, 05:18 AM
