Results 1 to 10 of 13
Thread: Pro Tuning Enabled
    Aug 2019
    Default Pro Tuning Enabled
    What will pro tuning allow me to do on Cummins ECM and PCMs?
    Nothing extra, it was more for GM gas ECM's.
    Aug 2019
    I heard that you can flash in a 2018 file into the 2013-2017 trucks. Is this correct? Also is there now user-defined parameters.
    Jan 2020
    You can flash a 13 to 17 file into an 18 and an 18 file in to a 13 to 17 truck. You should try it. It won't be right....
    User defined parameters is HPTuner lingo. Anything user defined in EFILive is completed with the .cax (or update format) file.
    Jan 2016
    Quote Originally Posted by whistler View Post
    18 file should work fine for 13-18
    Jan 2020
    Quote Originally Posted by TWITCH02X View Post
    I have not witnessed that. I have placed a known good file for a 2015 truck onto a 2018 truck and codes for the MAP and MAF sensor existed. Yes, the MAF and MAP sensor were plugged in. Both trucks were the same trim package and had the same level of modification. I have since modified a 2018 specific file for 2018 trucks.
    Jan 2016
    I didnt say you could use 15 file in 18 truck, I said you could use 18 file for 13-18
    Jan 2016
    Didn’t mean to sound rude
    I have a 13 and my CTT files have all used an 18 file....
    Jan 2020
    You weren't rude at all, my ability to understand was low... Very interesting to know, thank you!
    Jan 2021
    Wow, pardon my struggles with English... I have not tried an 18 file in a 13 to 17 truck. I will have to give that a go.
    So the 32370831 file would work all the way back to a 2013?
  1. help! E67 enabled flex....
    By AGRO in forum E37, E38 & E67 PFI ECM's
    Last Post: November 24th, 2022, 07:50 PM
  2. Pro Tuning License
    By hacklerjason in forum E98 2014+ Diesel ECM
    Last Post: February 18th, 2018, 05:33 PM
  3. Pro Tuning
    By Road in forum FlashScan V2
    Last Post: December 16th, 2015, 10:20 AM
  4. Pro Tuning license
    By DURAtotheMAX in forum FlashScan V2
    Last Post: February 1st, 2015, 07:03 PM
  5. GEN IV swap AFM is not enabled
    By harascho in forum Gen IV V8 Specific
    Last Post: January 29th, 2009, 07:01 PM
