Results 1 to 4 of 4
Thread: 06 5.9 VIN is correct starts and dies after flash
    Aug 2019
    Default 06 5.9 VIN is correct starts and dies after flash
    I am struggling to figure out why this truck will start and die after a flash. The VIN is correct but it acts like it isn't. Trucks runs for a few seconds before shutting off.
    What about with the tune you read out of it, or a 100% known stock tune? (sometimes some of the handheld tuners don't do a true return to stock).
    Senior Member tylerltr450's Avatar
    Aug 2014
    is anti theft on?
    2006 Cummins Red, Auto to Nv5600, SBC 3600, Traction Bars, Visor, Running Lights, S&B Intake, ATS intake horn, EFI Live, Borg Warner S363 Turbo, Industrial Injection Dragon Fly Injectors.
    Aug 2019
    Got it figured out. I wanted to post the results here. Flashed in my tune file and the truck started. After a couple of seconds, it would shut off. Thought I had messed the VIN up but I did not. Tried multiple stock tune files and it did the same thing. Started thinking it had to be a security thing. Found a post on SKIM for people having problems with the key fob. Truck would start and die. This truck does not have a key fob. I called the owner and he said it never had one. I was thinking maybe this was it. The truck wasn't seeing the key fob. I disabled the anti-theft and turned of the DTC for SKIM. Flashed in the new tune file and ran perfectly. Dealer must have shut this off for the previous owner and when I flashed in the new tune file anti-theft was on. If you or your customer don't have a key fob be aware of this situation. Thanks, everyone for the help.
  1. 2006 5.9 Starts and dies after flash
    By Twistedshafts in forum Cummins 5.9L
    Last Post: January 24th, 2021, 11:39 AM
  2. LS3 Starts and immediately dies
    By TurboCamaro in forum E37, E38 & E67 PFI ECM's
    Last Post: June 22nd, 2015, 05:44 AM
  3. Starts but then dies
    By Johnnydangerously in forum Gen III V8 Specific
    Last Post: June 12th, 2012, 03:03 PM
  4. Starts, reduced power, and then dies...
    By snax in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 27th, 2010, 10:57 AM
  5. starts for 1 sec and then dies
    By Cablebandit in forum Custom Operating Systems
    Last Post: April 8th, 2007, 12:32 PM
