Results 1 to 10 of 10
Thread: January 2021, V8.3.4 Beta 1
    Default January 2021, V8.3.4 Beta 1
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V3/V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
    Attention:
    Full Release Notes:
    Version Numbers:
    • EFILive V7 software: V7.5.33 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.3.4 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • FlashScan/AutoCal V3 Firmware: V3.00.058 (Jan 22, 2020).
    • FlashScan/AutoCal V2 Firmware: V2.07.168 (Jan 22, 2020).
    Download here:
    Known Issues:
    Issue #1:
    None.
    Workaround:
    None.
    Regards,
    The EFILive Team
    May 2010
    I install it in new laptop
    It seems there is some thing wrong with v7.5 it keeps ask me to register
    I enter the registration info and restart the application the demo will gone but when I disconnect the V2 and restart v7.5 it will goes to demo again
    EFILive Tuner
    Do you have your V7 registration details entered correctly?
    If they are not entered correctly, then:
    1. having V2 connected will bypass the registration details validation and you won't see any demo mode.
    2. having V2 disconnected will fall back to demo mode.
    Send me the registration details that you have entered and I will check if they are valid.
    Send to paul@efilive.com
    May 2010
    Thanks Paul
    every thing is fine now I will keep testing and will let you know if there is any problem
    EFILive Tuner
    New Member Dleger89's Avatar
    Sep 2018
    Any feedback so far?
    Quote Originally Posted by Dleger89 View Post
    Very close to the next beta update planned for end of this week.
    Dec 2012
    Does this update include the ability to load CAX8 files without a CAM file?
    Josh
    '04 GMC LLY
    For selected controllers, yes: E55, E69 and E77.
    You can see in the cam folders for those controllers the empty 99999999.cam file.
    The 99999999.cam file is loaded if/when a tune file is opened for which no matching *.cam file can be found. The 99999999.cam file has no calibrations defined in it, so any additional *.cax8 files that are loaded will contain the only calibrations that show up.
    I can add equivalent 99999999.cam files for other controller types - which ones would be most useful to start with?
    Dec 2012
    Could you do A50, E98, T87 and E35A&B whenever you have a chance?
    Then I can get to town testing out V8 Editor!
    Josh
    '04 GMC LLY
    Beta 2 update posted here:
    https://forum.efilive.com/showthread...-V8-3-4-Beta-2
  1. January 2012 GMHTP Magazine... Efilive at work.
    By Redline Motorsports in forum Lounge
    Last Post: October 31st, 2011, 04:19 AM
  2. January 24th 2011 pre-release
    Last Post: April 10th, 2011, 04:17 AM
  3. January 2011 update
    By GMPX in forum Cummins 5.9L
    Last Post: January 15th, 2011, 07:28 PM
