Results 1 to 7 of 7
Thread: Security Unknown Message During Write
    Senior Member Jim P's Avatar
    Nov 2019
    Default Security Unknown Message During Write
    Long story short, was pissing around tuning with HP Tuners on my 2012, was always leary of HP Tuners. Anyways, it bricked the ECM after a few months of using it, ordered a used one programmed to my VIN, loaded up a tune on the
    It might be a long story but your post was cut short....
    Nov 2019
    Ah, what the hell lol.
    Nov 2019
    I loaded a tune to the “new” ECM with EFILive, didn’t apply the RSA patch first. It gave a security “unknown” message after sending an unlock key, then after the message send an unlock key again and wrote the tune. That normal?
    Nov 2019
    It takes writes and the truck runs fine other than some gremlins after the bricking of the original ECM from HP Tuners. When I turn the ignition to on, the exterior lights and instrument cluster illumination flashes twice. Other than that, everything is normal in operation of the truck.
    If the ECM hasn't had the anti-tuning stuff turned off then it will still take a stock tune no problem.
    Are you sure you started with the correct base calibration? (It will be written on the sticker on the 'dead' ECM).
    Nov 2019
    Yessir, CM90032. Wasn’t a pure stock file that I loaded to the “new” ECM though either, truck won’t run right or very well without some particular modifications in the tune file.
  1. Security light
    By JDPlowboy in forum Duramax LB7
    Last Post: July 15th, 2015, 11:20 AM
  2. Persistent security light
    By vortecfcar in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 8th, 2012, 08:59 AM
  3. Security Light
    By ZR2_350 in forum FlashScan V1
    Last Post: August 8th, 2010, 04:23 AM
