Results 1 to 4 of 4
Thread: Pid for airflow grams/cyl - E92 5.3L
    Jul 2012
    Default Pid for airflow grams/cyl - E92 5.3L
    I'm trying to log airflow in grams/cyl as calculated by the ecm for knock retard logging and timing adjustments. I tried logging APCYL_M and my V2 says it's an unsupported PID when I attempt to log data. I have V8 8.2.2 build 290 and OS #12663390.
    Is there another PID I should be using instead? I am using a calculated PID referencing the MAF sensor in the interim, but I don't trust that as much as the value the ecm calculates when it determines spark advance.
    Vehicle is a 2014 GMC Sierra 5.3L
    Thanks in advance
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Sorry but there is no alternate PID, any PID with '_M' or 'DMA' is not a standard GM PID instead it requires EFILive to find specific info for each and every OS we want to add this PID for. It is very time consuming and unfortunately is something that I do let lapse and have done on the E92. I can do no more than say I will attempt to add them in at some point.
    Jul 2012
    Understand. There are several versions of MAF airflow on the E92. Which one would you recommend to be most accurate? I'm using the generic MAF PID right now.
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Mar 2020
    I know this is an old thread but I'm in the same boat as Wheelz. I'm trying to tune the MAF sensor after a new intake and intake tune install on a 2017 chevy silverado 1500. Is the generic MAPF PID the best pid to use?
    -Thanks
  1. What PID can I scan this airflow value with?
    Last Post: June 14th, 2013, 08:29 AM
  2. change spark table fron grams/cyl to map
    By dags in forum Custom Operating Systems
    Last Post: August 27th, 2012, 03:07 AM
  3. Turbo LS4 odd dma grams/cyl problem with mass air on the dyno
    By MattS in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 17th, 2011, 02:21 PM
  4. grams/cyl not matching from tune/ scan tool
    By Dmaxink in forum Gen III V8 Specific
    Last Post: December 22nd, 2009, 04:20 AM
  5. DYNCYLAIR_DMA never above 0.50 grams/cyl?
    By S10Wildside in forum General
    Last Post: September 7th, 2008, 09:22 AM
