Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: February 2021, V8.3.5 Beta 2
    Yes, you can open/save individual map files or copy/paste individual maps using these options:
    Use Right-Click -> Map Properties (Shift+F6) to display the Map property editor.
    Attachment 23665
    You can even copy maps from V7 to V8 using the [Copy for V8] button, then just click the [Paste] button in V8 to paste the map from V7.
    Attachment 23664
    I made a post about weeks ago and wasnt told anything. I havent used V8 because I wasnt going to spend all the time to remake everything from scratch since I dont use efi very much anymore.
    Smile Some of us are having a problem with this.....
    I know you like V7, but it is time to take it out the back and shoot it
    At least I know I'm not alone....
    Chuck CoW
    Quote Originally Posted by minytrker View Post
    Sorry, I don't see every post. If there's something that you don't get an answer for - just PM me (or Joecar or GMPX or Tordne) with a link to the thread.
    Quote Originally Posted by Chuck CoW View Post
    Chuck CoW
    V7 will still keep working. But there won't be anymore development or new features for V7.
    Jul 2003
    V8 is more powerful. No doubt about it. But V7 is the standard which I judge any other software to be honest.
    V7 has something in the charts that makes it so easy to spot changes and anything happen.
    Although lately I haven't used V7 Scanner in a couple of months, and you apparently fixed a bug with the calc pids which i am happy for. I have added almost all the custom parameters I need. I have been moving away. But it still shares a big place in my tooner heart. I mean, we've been using it for 10 years now?
    May 2010
    It seems the copy/past and multiply with labels is not working wjen used in V8 scanner and V8 editor
    if I paste and multiply with label the data I copied from V8 scanner in the V7.5 editor it will show "Cant find any matching col/row labels, no data has been pasted"
    So it seems there is something wrong with the V8 scanner or the way I define the rows and columns
    second issue I will attach photos for the buttons was available in V7.5 but not in V8 in the DTC and many tables like speed limiter Click image for larger version.
ID:	23681Click image for larger version.
ID:	23682Click image for larger version.
ID:	23683Click image for larger version.
    EFILive Tuner
    Jul 2003
    You need to set the column value as "Value". Otherwise it won't paste.
    Jul 2003
    On the buttons. Just click on top of them. it will work
  9. #19
    Enumerated values (i.e. text based values) are implemented in V8 as drop-down lists.
    You can click on the cell to drop down the list and select the value using the mouse, like this:
    Or you can press the first letter of the enumerated value to select that value. If multiple values have the same starting letter, keep pressing that letter to cycle through all values that start with that letter.
    If you want to change, multiple enumerated values at the same time, select all the ones you want to change (you can select disjointed groups by holding the CTRL key and clicking each individual cell, or contiguous ranges by holding the SHIFT key). then click on the focused cell (the one with the dark blue background) to drop down the list and select the value. All selected cells' (that have the same enumerated options) will be updated.
  10. #20
    Good info, thanks for explaining (first letter of enumetated value is very handy).
  1. January 2021, V8.3.4 Beta 1
    Last Post: February 21st, 2021, 05:59 PM
  2. February 26th 2011 release candidate 1
    Last Post: March 4th, 2011, 09:55 AM
  3. Why is BBL not out of beta? Or is it out of beta?
    By Highlander in forum Black Box Logging
    Last Post: June 9th, 2009, 07:10 PM
