Results 1 to 10 of 20
Thread: February 2021, V8.3.5 Beta 2
    Default February 2021, V8.3.5 Beta 2
    NEW BETA RELEASE IS NOW AVAILABLE. PLEASE SEE LATEST BETA SOFTWARE FOR DOWNLOAD LINKS
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V3/V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
    Attention:
    WARNING:
    Due to the new security/encryption option in this release, all tune files saved using this release will no longer be compatible with older versions of the V7 or V8 software. If you distribute tune files to other users (i.e. your customers), the recipients must be:
    • using this version or a later version of the V7 and/or V8 software.
    • using this version or a later version of the V2 and/or V3 firmware.
    Full Release Notes:
    Version Numbers:
    • EFILive V7 software: V7.5.34 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.3.5 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • FlashScan/AutoCal V3 Firmware: V3.00.059 (Feb 22, 2020).
    • FlashScan/AutoCal V2 Firmware: V2.07.169 (Feb 22, 2020).
    Download here:
    Known Issues:
    Issue #1:
    Custom operating system (COS) upgrades are not being applied completely.
    If you have applied a COS upgrade to any tune file using the V8 beta software, please delete the resulting tune file(s). Those partially upgraded tune files will contain only a partial COS upgrade which will not work and may cause problems if flashed into a vehicle.
    Workaround:
    Use the V7 software to apply COS upgrades.
    Will be fixed in the next beta update which will be posted as soon as the fault is rectified.
    Issue #2:
    Saving an E98 *.coz file creates the file with some data missing. That will cause a $06FF (checksum) error if that *.coz file is flashed into an E98 controller.
    Workaround:
    None.
    Regards,
    The EFILive Team
    May 2010
    Thanks Paul I will test it and report back today
    EFILive Tuner
    May 2010
    Thanks a lot Paul for this update
    the WOS11 issue is fixed and its return valid data
    I love the V8 features for scanner and editor
    just we need the DVT control in V8 so we can fully switch to V8 and forget about V7.5
    EFILive Tuner
    DVT controls are very close (for CAN based controllers), they are in internal testing right now.
    VPW based controllers will be started after the CAN based DVTs reach beta testing stage.
    May 2010
    Paul Is there any way in V8 scanner to open MAPs which I defined in previous dashs instead of rework them from beginning ?
    lets say i have a dash for E38 and want to import some of them to E67 dash
    EFILive Tuner
    Yes, you can open/save individual map files or copy/paste individual maps using these options:
    Use Right-Click -> Map Properties (Shift+F6) to display the Map property editor.
    You can even copy maps from V7 to V8 using the [Copy for V8] button, then just click the [Paste] button in V8 to paste the map from V7.
    Default Excellent!
    Excellent!
    I think I was having trouble with exactly this on my last V8 scan adventure. I'm assuming that loading individual
    maps to the currently loaded dashboard, it prompts you to save the dashboard if it's been modified like this?
    Thank you.
    Chuck CoW
    Jul 2003
    EI EI EI.... don't go on knocking down V7.5...... not on my watch buddy.
    Quote Originally Posted by Chuck CoW View Post
    Excellent!
    Thank you.
    Chuck CoW
    Yes, it should do.
    I know you like V7, but it is time to take it out the back and shoot it
  1. January 2021, V8.3.4 Beta 1
    Last Post: February 21st, 2021, 05:59 PM
  2. February 26th 2011 release candidate 1
    Last Post: March 4th, 2011, 09:55 AM
  3. Why is BBL not out of beta? Or is it out of beta?
    By Highlander in forum Black Box Logging
    Last Post: June 9th, 2009, 07:10 PM
