Results 1 to 5 of 5
Thread: E98 Canada/NZ -NON USA user needing help with delete on 2018 Cruze
    May 2008
    Default E98 Canada/NZ -NON USA user needing help with delete on 2018 Cruze
    Hello there,
    I am a Canadian user of the V8/7.5 software platforms and have successfully used them for performing many DPF/DEF deletes on duramax pick ups, I am now looking to delete a 2018 chevy cruze diesel that will be used for off road rally use. I see I can make changes to the DTC list, desired boost levels, torque management etc but is this all that is required or our only options as far as deleting the emissions stuff off this thing?
    We are not looking to add any power really just eliminate the very troublesome emissions stuff.
    Ive attached the stock file as well.
    Thanks in advance!
    Although for some users the DTC tables will show there is likely a lot more involved to do what you want. But EFILive has never put in parameters specially to remove emissions components for this ECM.
    May 2008
    I've done it lots and lots of times on the trucks with good success but it appears not everything is mapped in this ecu with EFI Live. I know many people have and continue to successfully delete these cars so how are they all doing it?
    Well they aren't doing it with EFILive, I can assure you the parameters required to do this are not and have never been in the software.
    Mar 2021
    Hello Friend, you have the stock file, for Chevrolet Colorado 2.8 Diesel 2016
  1. 2017.5 E98 USA Built
    By Road in forum E98 2014+ Diesel ECM
    Last Post: November 20th, 2017, 05:59 AM
  2. Overseas OS + Calibrations on USA E98 ECM
    By hacklerjason in forum E98 2014+ Diesel ECM
    Last Post: January 9th, 2017, 12:53 PM
  3. Any end-user E98 LWN USA solutions yet?
    By jackg23 in forum E98 2014+ Diesel ECM
    Last Post: June 18th, 2016, 12:46 AM
  4. High/Low Octane Tables Canada Vs. USA?
    By n6oli in forum Gen III V8 Specific
    Last Post: June 13th, 2007, 04:18 AM
