Results 1 to 5 of 5
Thread: Dodge Cummins 2350B delete
    Oct 2017
    Default Dodge Cummins 2350B delete
    Hi all
    I can do deletes with on lml etc, but when i load stock ctz from cummins i dont have nothing in tables. is there other 3rd software to edit the files for delete and power ?
    Oct 2017
Name:	Screenshot 2021-02-23 21.05.21.png
    This it what i see when i open ctz from cummins, i dont have any maps or system
    EFILive has never had parameters to do deletes on these Cummins ECM's.
    Oct 2017
    Yes but it even not open the normal maps boost/timing/torque limiters etc..
    Actually that is a bug in the particular version of V7 you have there. You should be getting message that the OS is not supported.
    Reason being is Dodge must have replaced it with a newer calibration between EFILive software releases, we don't tend to go back and map every known OS on these ECM's because there is simply too many to do.
  1. Dodge ram 2350B
    By sohaib in forum Cummins 6.7L
    Last Post: January 22nd, 2020, 04:28 AM
  2. Cummins 2350B
    By got boost? in forum Cummins 6.7L
    Last Post: January 17th, 2020, 09:47 PM
  3. Replies: 1
    Last Post: May 19th, 2019, 10:09 AM
  4. Change VIN to older Dodge or non Dodge?
    By Master_Chase in forum Cummins 5.9L
    Last Post: July 26th, 2017, 04:14 PM
  5. Replies: 1
    Last Post: June 28th, 2017, 11:41 AM
