Results 1 to 7 of 7
Thread: Clarity to these T43 Shift Pressure Peramiters
    Jun 2020
    Default Clarity to these T43 Shift Pressure Peramiters
    Hi all, searched and searched for hours, did find one thread about the topic, but it was not rrelivent to the T43 6L80E Truck/SUV transmissions.
    Below are 2 images, both from optional 2007 Cadillac Escalade EXT programming. (1) is for the 24242131 18" Rim option, and the other is from the 24246751 22" Rim option...
    In Both pictures is the Parameters located under the Shift Pressures tables.
    The 18" calibration has Pattern 1 selected as the drop down menu item in the cell D7010
    The 22" calibration has Performance/Sport selected as the drop down menu item in the cell D7010
    Edit: Fat fingered one of the copy and pastes in this specific table. Weird that EFI live when you do a blanket copy and paste to these tables will automatically change that specific cell to Performance/sport. I scanned through the stock roms and could no0t find where I changed it, or that it even existed. I can repeat it though. So we can ignore the basis of it being changed, and something for the EFI live developers to check within the bounds of internal copy and paste. However, I would still like clarity to the selections below.
    Any one have clarity on these specific selections and what they mean?
    Options for these selectable patterns in this cell are:
    Normal
    Performance/Sport
    Cruise
    Winter
    Trailer
    Load Management
    Warm up
    Pattern 1
    Pattern 2
    Pattern 3
    Pattern 4
    Eco
    This is one of the few minor differences I see within the different calibration ID's for the same vehicle model and year.
    18" Rom Shift Pressure Parameter Image:
    22" Rom Shift Pressure Parameter Image:
    Any info is greatly appreciated
    Thanks,
    Ryan
    Quote Originally Posted by raceghost
    Is this still happening...?
    Jun 2020
    Yes. I can recreate every time I blanket copy and blanket past in this specific section and tables.
    Quote Originally Posted by raceghost View Post
    With V7 software, I take it.
    Jun 2020
    Ya, even on the latest release. Is 8 up and running yet?
    I can confirm that the copy/paste issue is a fault in the V7 software. When pasting the V7 software is only comparing the first character of the value being pasted before "deciding" it has a match for the cell's value.
    In the list of available values for that first cell, the "Performance/Sport" value is the first one in the list that begins with the letter "P" which is incorrectly being matched to the first letter of the value being pasted "Pattern 1".
    The same thing happens with the "Pressure Pattern" values. If you copy/paste all of those, they all change to "Pattern A" which is the first value beginning with P. You may want to check that your "Pressure Patterns" are all still set to the correct values - they look like they've been changed incorrectly/inadvertently too.
    Will fix in the next update of V7.
    V8 is available for editing T43, however it is still in beta and it is not recommended that you update your production systems to the beta version. If you have a second/spare PC that you can load the V8 beta version onto then you could edit using that.
    https://forum.efilive.com/showthread...-V8-3-5-Beta-4
    We hope to have a release candidate available soon that you can use on production systems.
    Also, in V8 you can right-click on the table and select "Copy/Paste Default Settings" which allows you to choose various copy/paste settings, one of which is "Copy Enumerated Text". That option determines whether the software copies the underlying numerical value for a text based cell or it's actual text value. You can copy/paste within V8 tables using either numeric or text values.
    Jun 2020
    Thanks Blacky, I was wondering if it was something like that. No worries. Hoping for V.8 soon.
  1. Need Help with T43 6L90 OEM Shift
    By gaduser in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 17th, 2017, 03:23 AM
  2. T43 corrupted file after editing (3-5 shift)
    By Eng.LSX in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 6th, 2017, 10:29 AM
  3. T43 TCC Desired Slip and Adaptive Pressure
    By Longslyde in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 11th, 2012, 07:42 AM
  4. Wideband Log Help : Clarity Needed
    By Mikz86ta in forum External A/D inputs
    Last Post: June 13th, 2012, 02:43 AM
  5. Replies: 1
    Last Post: August 23rd, 2010, 08:35 AM
