Results 1 to 2 of 2
Thread: Why do parameters seem to disappear sometimes?
    Default Why do parameters seem to disappear sometimes?
    You're editing a set of parameters something like this:
    Then you change a value that causes the display to get wider and a scroll bar gets added to the bottom of the page, like this:
    Then you click in the "Units" column and the table "scrolls" to reveal the units column which scrolls the "Value" column off to the left, effectively hiding it.
    You can click on this tool bar button to recalculate the correct widths and restore the display so you can see both columns (assuming your physical screen is large enough).
    Thanks (that's similar to Windows Explorer's resize to fit all columns).
  1. E40 Boost VE tablevalues disappear after flash...
    By rubbersidedown in forum Custom Operating Systems
    Last Post: March 18th, 2011, 01:39 PM
  2. Captions Disappear
    By Ninety8C5 in forum Do you want to be a Beta Tester?
    Last Post: May 20th, 2009, 08:28 AM
  3. New A6 Parameters
    By gmh308 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: March 15th, 2009, 08:33 PM
  4. Any one know what parameters....
    By 98SS2836 in forum Gen III V8 Specific
    Last Post: January 16th, 2007, 05:01 AM
  5. outside parameters
    By wkdivr in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2005, 02:13 PM
