Results 1 to 10 of 12
Thread: CMF 2019/2020 CSP-5 Issue
    Mar 2021
    Default CMF 2019/2020 CSP-5 Issue
    Wondering if anyone has had issues with the CMF Controller, Emission Compliant tune works perfect when its a single tune. Once converted to CSP-5 it will give Service Electronic Throttle message, traction control message, and will get all 6 injector codes but no ses light. only way to re-set the messages is to flash the ecm again.
    It's not something I've heard of, are you sure you are using the correct base calibration for the vehicle type for the CSP conversion? Eg, you aren't using a 2020 pickup file in a 2019 Cab Chassis.
    Mar 2021
    The file I used was a perfect match, and works fine as a single tune. I have tried using a different base file and got the same issue.
    I even converted the single tune that was working to the csp-5 and got the error not even 1 mile down the road.
    Not that anything has really changed since this first came out, but what V7.5 software version are you using and what is the .calz file date shown on the standard and CSP5 file when the tunes are loaded in V7.5?
    Mar 2021
    July 9th, 2020 is the file date.
    the software version I am running is V8.3.3
    Those dates indicate I don't think you are running the very latest public release:
    https://www.efilive.com/latest/downl...ublic-release/
    Because I am not sure what is going on with your issue I would suggest updating V7 to the Dec 2020 release, redo your CSP5 conversion once updated and see if the newly generated file exhibits the same problems.
    Mar 2021
    I checked my V7 and its Version V7.5.32. for the fun of it I hit the check for updates button and it said I am up to date.
    That makes no sense why your file date is July 9th, 2020, that is not what is included in the December V7.5.32 release, it should be showing 27-Jul-2020.
    Please just download and update your software with the December 2020 release (ignore the 'check for updates', just force it to update by downloading and installing).
    Mar 2021
    I did exactly as you asked and downloaded off the link you provided and it did change the date when I converted again. I will flash this file in tomorrow and report back.
    Thank you!
Name:	EFI-Live ScreenShot.jpg
    Your picture still shows 9th-July
  1. CMF 2450 VIN Change
    By trucks in forum Cummins 6.7L
    Last Post: February 24th, 2022, 02:35 AM
  2. 2019/2020 E90 scaning
    By jay p in forum Petrol / Gas
    Last Post: February 9th, 2020, 06:55 AM
  3. 2019 Ram RSA
    By Road in forum Cummins 6.7L
    Last Post: September 8th, 2019, 07:18 PM
  4. May 2019, Beta Release (Updated May 30, 2019)
    Last Post: May 28th, 2019, 04:43 PM
  5. Happy New Year 2019
    By joecar in forum Lounge
    Last Post: December 31st, 2018, 07:28 AM
