Results 1 to 8 of 8
Thread: 2011 LML A50 24259875 Bin File
    Senior Member Jim P's Avatar
    Nov 2019
    Default 2011 LML A50 24259875 Bin File
    I have a bin file for a 2011 LML A50 24259875/25889875 that doesn't want to load into v7.5 or v8 beta versions. Can EFILive Support take a look at it and take care of any padding or anything that may need to be done so it will open in v7.5?
    If you post the file up here we can look (but it'll be Monday NZ time).
    Nov 2019
    I've attached it in a zip file. I had to pull it out of a Motorola S-Record. I can attach that as well if desired. I don't know if theres an easier way to get it from S-Record to a .bin file but i opened it up in WINOLS to get rid of the Motorola junk so I just had the hex of the OS then copied it all into a blank file in a hex editor.
    I don't know what you used to read this but the markers that EFILive uses to identify the TCM type are missing and the file size is also wrong, but there is a MUCH bigger problem.
    There is an issue with either the read or the conversion to bin as there is massive chunks of data where bit 0 is cleared in each byte, this file is not usable.
    Nov 2019
    Well crap. Thanks for taking a look into it. What’s the correct file length?
    0x280000 bytes
    Nov 2019
    That was enough information that I was able to go back and got the attached to open up.
    Well that and it probably isn't corrupted any more
  1. LML 12644094 bin
    By DURAtotheMAX in forum Duramax 2011+ LML / LGH
    Last Post: May 17th, 2016, 08:29 AM
  2. 2011 a50 issues
    By 913YFZr in forum Allison 5 & 6 Speed
    Last Post: March 1st, 2016, 11:02 AM
  3. Lml bin file.
    By RADustin in forum Duramax 2011+ LML / LGH
    Last Post: June 1st, 2014, 12:23 PM
  4. anyone have a 2009+ A50 TCM file??
    By DURAtotheMAX in forum Allison 5 & 6 Speed
    Last Post: August 20th, 2010, 12:51 PM
