Results 1 to 5 of 5
Thread: CM2150 Support
    Dec 2020
    Default CM2150 Support
    When will there be PID's available?
    The problem we ran into is inconsistency between all the years of OS's on this ECM.
    Most of the time many of the PID's are ok to use but sometimes they will simply not work between two different applications using the CM2150.
    We've not been able to come up with a workable solution to overcome this (aside from simply limiting the selection of PIDs down to a bare minimum).
    Dec 2020
    I see a CM2150E has been identified in the latest update. I have a CM2150D and most of the PID's do not work. I get RPM but I really need EFT's.
    You need to select just the 'CM2150', not the 'E' version as that one was the one that was different to all before it.
    Dec 2020
    Thank you. I’ll try that.
  1. Cummins CM2150
    By Awalution in forum Cummins HD
    Last Post: August 8th, 2019, 09:17 AM
  2. Cm2150 isl epa07
    By Stevec in forum Cummins HD
    Last Post: March 12th, 2019, 12:49 PM
  3. Support for Cummins CM2150 controller?
    By Bamfm7 in forum Cummins HD
    Last Post: August 30th, 2018, 12:45 PM
  4. no 3.8 support?
    By Madspeed in forum General
    Last Post: May 14th, 2013, 10:02 AM
  5. CAN support?
    By QUICKSILVER2002 in forum General
    Last Post: April 27th, 2005, 11:22 AM
