Results 1 to 4 of 4
Thread: 03 6L 4L80E VSS 1/2 GPS Speed
    May 2009
    Default 03 6L 4L80E VSS 1/2 GPS Speed
    I have a 6L 4L80E swapped vehicle that was brought in for a speedo calibration as it shifted hard and the speedo wasn't calibrated for the gears and tire size.
    The engine, trans, harness and computer all from an '03 4x4. The output of the trans was changed to make it a 2WD and the VSS was moved to the trans tailshaft from the TCase.
    I didn't do the initial cal for the swap so don't know all that was changed from stock.
    Upon calibrating for the gears and tires the VSS was off by about half (GPS showed 50MPH and VSS showed 27). I thought at first it was thinking it was in lo range on TCase and maybe pin 16 was grounded but this is not the case.
    I tried to cheat it by offsetting with the speedo calc now the VSS and GPS match but it is shifting at 2x the mph at TPS in the part throttle shift tables ( 1-2 shifts at 39 when it should shift at 19, 2-3 shifts at 40 when it should shift at 19, what a coincidence these are the same value although different TPS).
    Any thoughts?
    Attached are calibration as pulled and the current cal with log file.
    Eldon
    Mike_28Mar2021__0000.efi
    Mike_1965_C10_12582603_Shifts_0.8_28Mar2010_0005.ctz
    Mike_1965_C10_12582603_Pull_Cal_27Mar2010.ctz
    Quote Originally Posted by TurboCamaro View Post
    Any thoughts?
    Eldon
    Remove rear VSS and look in the transmission. See if there is a reluctor/tone ring for it to read off of. I had a "built" 4L80E that they must have used a 4x4 rear carrier cause the reluctor was missing and i was picking up the park pawl teeth.
    Also double check wiring from ISS/VSS to PCM. Make sure they are in the correct pin location and not mixed up at the transmission.
    Might want to start with a factory transmission tune and adjust from there. Worked on a old suburban with a 4.8/4L80E swap and it took forever to get it to shift right. Had to start over from a stock tune, whoever had tuned it before had it so far off it wasnt funny.
    May 2009
    Thank you.
    Will check these.
    Would anyone have a stock 12582603 Cal I could leverage for this. It is an '03 6.0L w/4L80E
    Thank you.
    Will check these.
    Whats your email?
    PM me if you want
  1. 4l80e to six speed (cda009)
    By Joemmahaffey1 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: April 29th, 2020, 05:25 AM
  2. Replies: 4
    Last Post: August 7th, 2014, 03:24 AM
  3. I want to install a GPS on my V2
    By Highlander in forum FlashScan V2
    Last Post: July 25th, 2013, 11:04 AM
  4. LS3 Swap, VSS, Stalling, speed control
    By Yngve in forum E37, E38 & E67 PFI ECM's
    Last Post: August 31st, 2012, 01:51 AM
  5. E38 and 512 gps limit
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: March 31st, 2011, 11:12 AM
