Results 1 to 4 of 4
Thread: Updated to Version: 8.3.3 now issues with fuel pressure tables
    Mar 2008
    Default Updated to Version: 8.3.3 now issues with fuel pressure tables
    The fuel pressure tables are messed up.Click image for larger version.
    06 GMC 2500 CCSB SLT LBZ 4X4
    These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
    Mar 2008
    More tables have issues there is no scale for the rows.
    Mar 2008
    Ok now I see you have to set the Row units, but how do you save it then. I close the tune and reopened and they went back...that was a huge wast of time.
    Quote Originally Posted by Dozerboy View Post
    If you change the units and or precision of the data, row or col values, those changes are (should be) automatically stored in a file called:
    \Documents\EFILive\V8\Config\XXX.cal_layouts.ini
    where XXX is the controller type of the tune file you are editing.
    for example:
    Here is the "saved" config for the e38 High octane spark table B5101
    Code:
    [B5101]
    Split.Horz=0.488247863247863
    Split.Vert=0.411883182275932
    Pan.X=-0.0490654205607477
    Pan.Y=-0.0488997555012225
    Rot.X=32
    Rot.Y=-110
    Zoom=30
    Data.Units=
    Data.Prec=1
    Col.Units=g/cyl
    Col.Prec=oz/cyl=4
    Row.Units=rpm
    Row.Prec=0
    Note: the Data.Units= value should be a degree symbol - but the forum won't show it correctly so I removed it.
  1. Fuel Pressure Tables And Dual Fuelers
    By EverydayDiesel in forum Cummins 6.7L
    Last Post: December 11th, 2017, 05:54 AM
  2. Replies: 5
    Last Post: May 23rd, 2014, 03:31 AM
  3. Fuel Rail Pressure Issues
    By WisconsinHick1 in forum Duramax LB7
    Last Post: July 26th, 2012, 08:39 AM
  4. Fuel Pressure Tables
    By FUBAR in forum Cummins 5.9L
    Last Post: February 25th, 2012, 04:29 PM
  5. Fuel Pressure Question - Missing Tables?
    By Jack_the_Diesel_Killer in forum General (Diesel)
    Last Post: May 16th, 2009, 05:24 AM
