In light of recent threads, I have went through some of the scripts I use and have decided to share them with the community. Use these at your own risk and make sure you know what you are changing. Also pay attention to the type of data being used and its format, as it may be different then what the script was wrote in. There are 31 contained in the zip. Below is a list of what is included.
DISABLE SKIP SHIFT (CAGS/CARS)
DISABLE COT (CATS)
DISABLE LTFT'S
DISABLE/ENABLE CLOSED LOOP
DISABLE/ENABLE OPEN LOOP
DISABLE/ENABLE MAF
DISABLE REAR OXYGEN SENSORS
INCREASE TRANSMISSION SHIFT FIRMNESS BY 10%-40%
IFR TABLE FOR THE FOLLOWING (SVO 30LB/42LB, MOTRON 60LB, STOCK INJECTORS FOR 98+ FBODY)
DISABLE TORQUE MANAGEMENT
REDUCE TORQUE MANAGEMENT BY 10%-75%
DISABLE/ENABLE DFCO
Hope this helps some.
PS - If you don't know what a script is, don't ask.
www.greenlightmotorsports.com/download/Scripts.zip
