Results 1 to 8 of 8
Thread: PCM OS to EPA vs California Emissions
    Aug 2011
    Default PCM OS to EPA vs California Emissions
    I'm in the process of doing a smog legal swap and even though I'm not in California the emissions system from the donor vehicle was a California emission vehicle. When I changed OS's to a different different vehicle (I'm using a 4L80E) the calibration file didn't have the last 8 of the vin (they were set as all 0's) and I cannot verify which type of emissions the tune file was equipped with. I'd prefer to not buy the more expensive California catalytic converter unless I have to. Is there any way to tell via the tune file which emissions the vehicle had?
    Due to how the vehicle is checked for the initial smog inspections the O2's cannot be switched off, so that is not an option...
    Thanks,
    Kyle
    Dec 2018
    should be able to go to scan tool and go to obd2 tab
    Dec 2018
    is the referee where you are at making you go to dealer for program verification.. the ones here in cali do.. they make you wire in bcm and everything else. we cant turn off vats til after ref has approved the swap.
    Aug 2011
    Quote Originally Posted by 74n72impalalq94l80 View Post
    Nevada,
    From what the DMV Tech told me is they check for set monitors, reset the ecu and check to make sure there are no preset monitors (damn it!), and then come back once all the monitors are set again.
    Don't see anything that says EPA or California emissions guess back to the drawing board...
    Try logging this PID:
    Aug 2011
    Once logged does it give a # for which compliance it is?
    Quote Originally Posted by cyipher View Post
    Yes, it will log/display the OBDII compliance number. Not sure if that single PID is "enough" to determine the requirements for passing emissions.
    I just tried two different OBDII controllers:
    E38 (not sure what vehicle it was from) which returned 13 = "JOBD, EOBD and OBDII"
    and
    E39A from a Chevy Impala V6 which returned 11 = "JOBD and OBDII"
    Kyle,
    What was the donor vehicle (year/model) for the engine, what smog devices was it equipped with? Do you know its VIN?
    The tune doesn't know the difference between CA and other catalyst.
  1. PCM OS to EPA vs California Emissions
    By cyipher in forum Conversions / Aftermarket Parts
    Last Post: April 13th, 2021, 07:29 AM
  2. PCM OS to EPA vs California Emissions
    By cyipher in forum Gen III V8 Specific
    Last Post: April 13th, 2021, 07:28 AM
  3. Replies: 1
    Last Post: January 27th, 2013, 06:48 PM
