Results 1 to 4 of 4
Thread: Error $0101 no data received
    Apr 2021
    Default Error $0101 no data received
    I am doing a swap with a Duramax 08 LMM, when I try to read the ECM with ether EFILive or my scan tool I get a failure, the engine seems to be running OK but I have a MIL light and would of course like to be able to work this out.
    I have another 08 LMM in the yard and both EFILive and the scan tool work fine on that vehicle. I am assuming there is a problem with the stand alone harness but would welcome any input, I get the same failure when trying to read the TCM
    I did not have EFILive when I test ran the engine before pulling it.
    THANKS!!
    Apr 2021
    OK, I did not know the data went through the glow plug controller, so I jumped that plug and I can now read the TCM, I get the "cannot read DSP5" error on the ECM, I of course do not have access to the original DSP5 file so can I simply dump a "stock" file and start over?
    Yes, if you're able to scan the ECM and read the TCM you'll need to write your own DSP5 tune and use that. Need to source a stock file for your truck and Full Flash it (either as a base OS or DSP5) then use that for future changes.
    Apr 2021
    THANKS! I have a stock tune from a library, I really do not need DSP-5, I am curious will the new flash have the original VIN of the ECM or will it assume the VIN of the donor tune? not a big deal as nether have anything to do with the VIN of the vehicle the LMM is in now, and I of course have not used a license on this ECM yet. Hopefully I can find a tutorial on doing a full flash.
    Again thanks for taking time to respond!
  1. $0101 No Data Received & First Post
    By JLBarstad in forum General
    Last Post: November 5th, 2018, 01:05 AM
  2. Replies: 6
    Last Post: June 28th, 2017, 11:30 AM
  3. Script exited with code $0101: No data received
    By paint94979 in forum Duramax LB7
    Last Post: January 14th, 2015, 07:37 PM
  4. Replies: 4
    Last Post: September 3rd, 2013, 08:18 AM
  5. Autocal Read Error $0101 No data received
    By firehawk in forum AutoCal
    Last Post: April 14th, 2013, 10:36 PM
