Results 1 to 4 of 4
Thread: What MPH shifts for 342 gears with an automatic?
    Jan 2005
    Default What MPH shifts for 342 gears with an automatic?
    I just ordered my Moser 12 bolt with 342 gears and need to know the MPH shift points? I am going from 273 gears to the 342's. Thanks for the help guys.
    EFILive can rescale the shift points for you.
    I did this when I went from 3.07 - 3.73, it was pretty close, then I just tweaked them to suit how I prefer the shifts.
    Be aware, there is a bug in the shift point calculator prior to V7.1.9 (not released yet) . It particularly affects Corvettes.
    The new V7.1.9 should be available soon - with a correct functioning speedo and shift point calculator.
    Sep 2003
    Sounds good thanks guys.
  1. automatic updates
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2008, 03:28 PM
  2. 4th to 2nd Downshift (Automatic)
    By TNTFEDZ in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 18th, 2006, 01:19 AM
  3. Different AFR´s in different Gears?
    By Treurentner in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2005, 08:46 AM
  4. Getting different AFR's in different gears ? Why ?
    By J 98ta in forum General (Petrol, Gas, Ethanol)
    Last Post: October 12th, 2005, 04:43 AM
  5. SD tune + Automatic
    By Phil99vette in forum General (Petrol, Gas, Ethanol)
    Last Post: August 10th, 2005, 04:35 AM
