Results 1 to 7 of 7
Thread: Stand alone LMM U0073 code
    Apr 2021
    Default Stand alone LMM U0073 code
    I am not sure this is the correct forum but I have a stand alone LMM and am chasing a U0073 "communications bus off" and wondered if anyone had any ideas, I have programmed all the "missing" controllers as "not reported"
    Oct 2010
    The DTC settings don't always work as labeled. In stand alone mode some network codes will always be listed. If no check engine light, don't worry about it. Light on, try changing to No MIL setting.
    LMM will run happily stand alone with a few yellow codes showing.
    Sent from my SM-G892A using Tapatalk
    Apr 2021
    Quote Originally Posted by kidturbo View Post
    Thanks, I went to a fair amount of effort to mount a large MIL light on the dash, was really hoping to use it (may have been a big pipe dream) I can find no reference to the U0073 in the DTC table, if I could I would just turn it off.
    Oct 2010
    I don't have any problems getting MIL off in stand alone. Is engine running? Have noticed MIL will stay on 10 sec after key on or start in my setups.
    Apr 2021
    Yes the engine is running, light stays on
    Oct 2010
    Here is the DTC settings list I pulled from a current LMM file I run in stand alone mode. Compare to yours and maybe find the the one tripping your light.
    -K
    X: Not Reported, No MIL
    Non Emissions, MIL On
    Non Emissions, MIL Off
    2 Trips, Emissions Related, MIL On
    2 Trips, Misfire Emissions Related, MIL On
    Non Emissions Related, MIL On
    Apr 2021
    Thanks, I will give that a look see
    -K
  1. E78 - 2017 Sonic 1.4t Code 95 Code 84 on dash
    By sama13 in forum E78, E83, E84 PFI ECM's
    Last Post: September 12th, 2018, 10:05 AM
  2. Help with TCM tuning on 2010 LMM code says doesnt support A50
    By darins28 in forum Allison 5 & 6 Speed
    Last Post: April 23rd, 2013, 11:27 PM
  3. Code P062F and Code P0633 Help
    By Airtime in forum General (Diesel)
    Last Post: September 28th, 2009, 12:57 AM
  4. Stand Alone Yet?
    By vandykeben in forum FlashScan V2
    Last Post: June 12th, 2007, 02:43 AM
