Results 1 to 3 of 3
Thread: VE smoothing function not working as it did before update
    Member TorqueMonster007's Avatar
    Aug 2013
    Default VE smoothing function not working as it did before update
    Just updated to V8 3.5 and associated V7.5. I have noticed that on E38,E67 and E92 ECMs that both V8 and V7 editors will not save small commanded VE changes but will only average out large changes with associated cells. Am I missing something with the new update that I haven't really noticed before? For instance if I take a cell in a stock VE and just put "0" it will not command "0" for that cell but will lower it and average down the cells around it. I noticed this when I was trying to adjust and smooth a VE in an E38 and it was not saving my commands. Any help with this? FWIW: V2 is connected and reading/ working properly at this time. It is not in "Demo" mode. Bootblock and Firmware are also up to date. Also tried saving as under a new name with same results. So if you were to smooth a small dip or peak it will not allow you to as I was trying to do.
    2024 3500HD (SRW) Duramax Denali Reserve
    2021 Ram 4500 Limited (Horse Hauler)
    2016 LML 2500HD Duramax High Country with a little help
    2022 Yukon Denali
    Aug 2013
    Anybody have anything? Suggestions? Was there something that defaulted with the update I wasn't aware of?
    2022 Yukon Denali
    See your other thread on this topic.
  1. Smoothing the VE Table?
    By Rich Z in forum Gen III V8 Specific
    Last Post: January 30th, 2013, 10:58 AM
  2. table smoothing
    By gigabrock in forum Duramax LB7
    Last Post: October 5th, 2012, 07:08 PM
  3. VE Smoothing
    By nonnieselman in forum Gen III V8 Specific
    Last Post: September 8th, 2008, 07:19 AM
  4. What are your smoothing techniques
    By Dirk Diggler in forum General (Petrol, Gas, Ethanol)
    Last Post: June 23rd, 2005, 12:08 PM
