Results 1 to 6 of 6
Thread: Up-to-date FlashScan v2 Won't Work With 2019+ Ram
    Senior Member Jim P's Avatar
    Nov 2019
    Default Up-to-date FlashScan v2 Won't Work With 2019+ Ram
    All my software, FlashScan v2 is up-to-date but I can't get it to work with the 2019+ Ram 6.7L. Don't see any CM2450 CMF options at all. What am I possibly missing here?
    "Don't see any CM2450 CMF options at all." What are you trying to do, scan, tune?
    Nov 2019
    Scan. Looks like I’m the documentation there should be some PIDs I can set for scan and logging on the v2 but nothing comes up with CMF, stops at CME.
    V8 allows some generic PID's to be logged, but for these ECM's it is mainly based on EDA logging which does mean the ECM needs to be running a CSP5 OS, not the normal OEM OS.
    Nov 2019
    So can only be done when on pass-through with the v2 and v8 software? I didn’t use a CSP OS on the truck.
    No, you can program the PID's into the V2 using V8 for BB logging. But the PID's aren't great on the CMF which is why we did EDA (where possible).
  1. 2019 Ram RSA
    By Road in forum Cummins 6.7L
    Last Post: September 8th, 2019, 07:18 PM
  2. I would like to beta test for the 2019 Ram 2500 6.7L Cummins.
    By CumminsTwang in forum Do you want to be a Beta Tester?
    Last Post: August 5th, 2019, 01:47 AM
  3. May 2019, Beta Release (Updated May 30, 2019)
    Last Post: May 28th, 2019, 04:43 PM
  4. New PCM, A/C won't work and it's 104!
    By puddlestomper in forum Duramax LB7
    Last Post: August 31st, 2013, 04:50 AM
  5. VDASH won't work
    By zacksfoam in forum FlashScan V2
    Last Post: August 14th, 2009, 05:04 PM
