Results 1 to 2 of 2
Thread: Restore VATS?
    Apr 2021
    Default Restore VATS?
    I installed a salvage ECM in my 08 LMM, I did a full flash from my saved tune but had to disable VATS to get it to crank, is there any way to restore the VATS other than the lengthy procedure turning the key on and off?
    Nov 2023
    Connect EFILive to your original ECM and read the tune file.
    Save the tune file as a backup.
    Open the tune file in EFILive and go to the Engine tab.uno online
    Under the Security section, find the VATS options and note down their values.
    Connect EFILive to your new ECM and read the tune file.
    Under the Security section, find the VATS options and change them to match the values from your original ECM.
    Write the modified tune file to your new ECM and clear any trouble codes.
    This should restore the VATS functionality on your new ECM without having to do the relearn procedure
  1. Vats
    By KillaKustomKables in forum E98 2014+ Diesel ECM
    Last Post: July 10th, 2019, 09:53 AM
  2. Replies: 3
    Last Post: April 6th, 2019, 11:26 AM
  3. Restore tunes after TCM failure
    By DMolaver15 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 12th, 2019, 01:44 AM
  4. Restore 56 Chevy Truck, adding GenIII V8
    By Sarel.wagner in forum Conversions / Aftermarket Parts
    Last Post: May 4th, 2014, 12:46 PM
  5. How to restore actual fuel rail pressure button?
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 24th, 2009, 04:59 PM
