Does anyone have any tips to get a CSP5 tune to increase idle speed? My goal is to have a switch-operated tune for high idle for warmup or winching. I do not have cruise control buttons to operate the factory high idle. On the duramax you can just put fuel in for 0% TPS but I cannot get this to work on the CM849. My strategy is to put values above 0 in the first column of the "Pedal Position to Desired Fuel" tables.
I have put values up to 40mm3 in the 0% TPS column up to 1200 RPM with no luck. In theory, with the throttle at 0% it should pull from the table and tell it to inject that amount of fuel, but in practice it doesn't work. Are there any settings or limiters that I should be looking for or other tables that I need to modify for this to work?
Thanks!
