Results 1 to 2 of 2
Thread: WHY am I not seeing all the codes?
    Apr 2021
    Default WHY am I not seeing all the codes?
    This is a stand alone with a ECM and TCM LMM Duramax
    So I connect the V2 to my DLC pick diagnostics, select read DTCs and it comes up with 4 selections, I cycle through all 4 and all I am getting are codes P0121 and P0140, and I have very low engine power, I have been chasing these codes for several days.
    So this morning I have an obvious miss, still no engine codes so I go back to my cheapo Autel and I see MAP, MAF and an open injector code, I do not understand why I do not see these codes on the V2 am I just stupid??
    Apr 2021
    OK, as it turns out I have a bad ECM, causing all the strange and about to drive completely insane issues, a ECM swap cured all of this up!!
    Of course now I have a sick 1 ton until a replacement ECM arrives but the HMMWV is so much fun to drive!!!
    The original ECM and drive train came out of a badly rolled donor truck everything was busted loose including the entire drive train, must have looked like a windmill in a tornado under that hood.
  1. Codes I getting while loading with v2
    By Todd1113 in forum FlashScan V2
    Last Post: May 15th, 2015, 08:33 AM
  2. LML codes
    By eficarnut in forum Duramax 2011+ LML / LGH
    Last Post: April 16th, 2015, 03:16 PM
  3. What do I need to scan for codes?
    By accentstencil in forum Gen III V8 Specific
    Last Post: July 29th, 2007, 08:28 AM
  4. Need help with a few codes.
    By slopokegtp in forum Gen III V8 Specific
    Last Post: July 27th, 2007, 11:36 AM
  5. o2 codes
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: June 5th, 2005, 06:20 PM
