After reading everything EFI has out on the web and the tune library not active anymore, I am hoping someone can help me out with a clean base file I can start playing around with for a pulling truck I am building. CMB controller
You are probably going to want to provide a bit more info about the vehicle, like What OS / Calibration is currently in the ECM ?
Or given this is for a pulling truck it might not be so critical.
I was thinking of starting fresh because I believe there is a modified Calibration ID on the CMB I have now. Not sure if that’s possible. Like I said this is a personal project truck I want to play around with so I want to start with a fresh clean file and slowly make changes.
Send me your email
Sent from my iPhone using Tapatalk
