Results 1 to 2 of 2
Thread: Hanging Idle Issue
    Jul 2021
    Default Hanging Idle Issue
    Hi guys, I am hoping someone may be able to give me some advice on fixing a hanging idle issue I have.
    I have gone into the throttle cracker table and zeroed out the cells from 1600rpm and below and this made no difference to my issue.
    When I unplug the IAC motor the revs return to idle nice and quick, as soon as I plug the IAC back in hanging idle is back.
    Would I need to pull some air from my base running airflow table ??
    And another issue I have is when I open the throttle hard from a idle speed I get a hesitation from the engine and sometimes a backfire in the
    exhaust before the engine comes to life and accelerates away, what table would I need to adjust to fix this ??
    Aug 2016
    Hi Rick,
    Are you able to post a copy of your tune and a log showing the hanging idle?
    Have you gone through the RAFIG/RAFPN tuning process at all? Have a look at these threads:
    First (look at the PDF): https://forum.efilive.com/showthread...dmon-idle-info
    Second: https://forum.efilive.com/showthread...ul-Info-Inside
    Regarding your hesitation/backfire, posting your tune and a log will help nail down the issue.
  1. Hanging Idle When Moving
    By ferocity02 in forum Gen III V8 Specific
    Last Post: October 3rd, 2013, 03:14 AM
  2. Hanging Idle with ETC
    By Matt68 in forum Gen III V8 Specific
    Last Post: May 6th, 2011, 12:30 PM
  3. Hanging idle.....what do you think?
    By Slow73 in forum Gen III V8 Specific
    Last Post: October 2nd, 2010, 01:36 PM
  4. Hanging idle
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2009, 03:24 AM
  5. Hanging idle on stock LS7
    By Stoichiometric in forum Gen IV V8 Specific
    Last Post: March 21st, 2008, 07:37 PM
