Results 1 to 10 of 14
Thread: 4L60E Transmission Torque Reduction during WOT
    Jan 2017
    Default 4L60E Transmission Torque Reduction during WOT
    Is there any reason why the torque reduction would not work during a WOT shift?
    My logs show that it's correctly pulling the timing during a 1 to 2 shift during a part throttle shift. During a WOT shift, no timing is pulled.
    PCM: GM LS1B
    OS installed: EFI Live Custom 04110003
    Torque Reduction Upshift tables: D0801, DO802, D0803
    Jan 2017
    I added a desired shift time of 0.2sec for the 1st to 2nd shift and now the transmission torque reduction is working at WOT. The shift time was 0 previously when it was only working at part throttle.
    Does the desired shift time need to be > 0 for the transmission torque reduction to be used during WOT?
    Thanks for posting.
    Moved to 4L60E section.
    I have seen TR not work at WOT, but I never realized this happens when desired shift times are zero.
    Yes, I would set the desired shift times to 0.1s-0.2s.
    A few quick questions:
    - which PCM do you have (part number),
    - which year/model/vehicle is the PCM,
    - which year/model/vehicle do you have,
    - what is the base OS id.
    I want to see which PCM's and OS's show this behavior.
    Jan 2017
    I'm going to set it back to 0 sec to confirm that this issue occurs again. I'll post the results.
    - PCM: GM LS1B: Service 12586243, HW 12583659, other numbers: 12587670, YFXJ. However, this is not the original stock PCM. The original got bricked so I got this one off of eBay with the same service #12586243.
    - year/model/vehicle: 2004 GTO
    - Base OS: 12587604
    Transmission: 4L60E PerformaBuilt with their custom shift kit
    Jan 2017
    CONFIRMED.
    Test: 1-2 shift time set to 0 sec.
    Results:
    - Part throttle: pulls the correct timing during the shift for the TR% set in the tune.
    - WOT: does NOT pull any timing during the shift.
    recrit,
    Thanks for the confirmation.
    Also try this (if you have the time):
    set the shift times to 0.001s and 0.01s and see if TR at WOT works properly in each case.
    Then, for normal running, set them to 0.2s (this is a quick shift, and TR sufficiently protects the trans).
    Dec 2016
    I'm not so sure you want the shift times at 0, the early stuff may not care but when the adaptives start doing their stuff in the later controllers, it very easily kills the trans :(
    You may want zero shift times when you have a shift kit installed.
  1. Torque reduction
    By Boosted GMC in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: July 4th, 2009, 07:42 AM
  2. TCM Torque Reduction Q
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 30th, 2007, 07:02 AM
  3. Removing Torque Reduction...what 4L60e mods??
    By MrZ71man in forum General (Petrol, Gas, Ethanol)
    Last Post: November 13th, 2007, 04:21 PM
  4. Torque Management reduction
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 30th, 2007, 11:28 AM
